Planter..WIP
I've also used wood hardener as an extra step for the feet of outdoor planters - and something extra that I do; a tip I read somewhere, is to dip them rather than paint it on, but just before dipping run a hot air gun over the foot to warm it up, then dip just before it starts to turn brown - this helps the hardener really get in there, as "good" wood doesn't soak it in quite as well as spongy wood.
I guess you could also use that tip for wood preservative on post legs.
Appreciate the tip fella, I'm sure I'll be making be making a couple more of these in future so will try the dipping method.
First time I've used hardener and I was quite surprised how thick a layer it produces, I could really feel it after running my finger
up the bottom part of the leg so gave it a sanding before painting.
I managed to get one put together last night, still a bit to do on it but at least it's freed some space up to work on the second.
With a little luck I might have them both finished for weekend.
    657.2 KB
I just need to get a nice image of them both in position at my folks, and job done...
Once the second planter was at the same stage as the first, I drilled and screwed the legs to the panels, then filled each
hole up with dowl. Once dry I trimmed them all with the multi tool, used a little filler where necessary and then a quick
sanding and a couple of coats of paints. I forgot to photograph the bases but I'll take an inside shot before I fill them up
with compost...
    519.8 KB
