9fingers
wizer":1ciqmtu1 said:I wasn't aware we disagreed on anything Cisco
It beggers belief why there is a sliding carriage on that saw. Why on earth did you buy it?
Pots and kettles?? :lol: :lol:
Bob
ciscoeuk":4fyxmnzs said:One question I have to ask. If these Defts (including the clones) are so good why are so few companies importing them?
Mike
to answer that part of the statement i can tell after doing some research, europe prefers to be suppled the sliding panel saws, but a lot of people just don't have room in the shop to fit the huge saws and opt for usa canada the DEFT style saws,
personally i prefer the deft style because it more versatile, and you can add on at your own pace and do a lot more that just cut sheet goods, with the sliding tables saw you are restricted to what you can do and the slide gets in the way
hope that answer a that point
Bluekingfisher":1g4wxzuv said:If perhaps you had read the earlier post from wizer (I believe) probably down to cost and a bigger mark up for the importer.
As far as talking out of my hat goes I have used one, hence my opinion of them. You have not as you mentioned never used or perhaps even seen the Deft/Laguana/Grizzly so maybe it's your hat that's doing the talking.
If you are happy with your SIP that's great Mike, my comments were in reference to the poor quality we have on offer and that too has been identified by contribitors on this forum and else where.
wizer":3iqvomvd said:It beggers belief why there is a sliding carriage on that saw. Why on earth did you buy it?
Mike.C":205cgk2l said:If the buyer does not have room for a sliding table or does not want to use one, then surely he would just buy the non sliding table model?
These tables saws are not set up to use a sliding table straight out of the box, and are in fact once put together set to use the fence with both the left and right hand extension tables fitted.
Take my 12" model for instance, if you want to use a sliding table then you have to remove the standard tape measure, and apply the one supplied with the sliding table, which takes into account the different fence positions, and allows you to install both extensions on the right hand side.
Now you say that the Deft type machine is more versatile, so bearing in mind the above statement about not using the sliding table, can you explain to me why this is the case?
Also with the sliding table why are you stuck with cutting just sheet goods? With one pull of a latch my sliding table is removed and tucked away within 30 seconds.
You either buy or don't buy the sliding table model, I cannot see the problem :roll:
I maybe wrong here, but I think that the only clone where you have to have the sliding table is the Axminster model, but even then you do not have to fit it.
Mike
9fingers":3tm4pwv2 said:wizer":3tm4pwv2 said:I wasn't aware we disagreed on anything Cisco
Bob
Bluekingfisher":1xecny29 said:The problem is Mike, many of the saws are only sold with the sliding carriage now and you have to pay for the privelage, so if you have no need nor want of it, it either lies in a corner gathering dust or goes on ebay. Besides, the extention wing to replace the carriage does not come with the package, so additional cost again.
So, in your opinion then, having used the Unisaw, does the SIP compare anywhere near the Delta in workman ship and build quality... be honest now :norm:
wizer":8nlnsx62 said:No I don't own the Record TS200 I own the Axi TS200 (equally a poor machine)
I haven't used the saw, But I'd played with it many times and wasn't impressed. Maybe it was poorly setup the few times I've seen it. But it just oozed cheap and nasty IMHO. I think a lot of these raving reviews for saws like both TS200's come from people who've never used a proper saw and don't really know what to expect. Also, I'm just not a fan of sliding tables on small saws. It doesn't make sense.
jedmc571":25vaelvf said:So with that in mind..............which Tablesaw should I buy :lol:
Jed
Mattty":2d6bbqtn said:This old piece of cast looks good value Wizer... better be quick though
http://cgi.ebay.co.uk/liner-table-saw_W ... 2303ebe295
Before it falls apart
