Floggedhorse
Hi all, I'm at a crossroads, I’m looking for direction, and any opinions much appreciated…
I have a Lurem C.210B, but the motor has finally given up the ghost, RIP, along with finally getting my garage back, and kids leaving the nest, I'm looking to set things up permanently, fixed and ready for action… want a saw it's there ready, want a planer, it's waiting… The garage is now ceramic floor tiled… “I know”
, it only took 16 months! Anyway, I jibber jabber…
It is confirmed, that it’s not worth rewiring, so I’m faced with a few choices.
Replace like with like
Tec 1.5KW, 2 POLE, 1PH, CAP CAP MOTOR B14 – Frame size 90S
Or
give la petite machine un peu de vä-ˌvä-ˈvüm! (before burning out, it never seemed to have enough oomph – but that might have been the motor on its way). It appears a 2.2kw motor will fit
but will it give me belt/power issues?
Tec 2.2KW, 2 POLE, 1PH, CAP CAP MOTOR B14 – Frame sizes 90L (30mm Longer) (it would need a 16amp supply) or is this unnecessary overkill?
(edit - it appears the original motor is very short, the Tec motor wont fit without cutting 17mm of the frame - but others will)
With
New switch gear with thermal overload
Why not treat it to a new drive belt, can you even buy them? (a part number would be a bonus please)
Or will I need to change the belt type, along with the pulleys
OR
Or a complete machine replacement with another combination saw, moulder, planer, thicknesser … but what? That’s another question.
Edit 2 - interesting from the manual it comes in two variants ... "2HP three-phase" or "1.5HP Single phase" motor
Or
With
OR
