I have a metabo that doesn't have a round body.
I also regularly use the router so don't want to bolt it upside down to the underside of my panel saw.
Normally in a router table you would use a much larger router that takes 1/2 cutters and not a trim router because you need both power and rigid cutters, the 1/4 shank cutters can be a bit lightweight.
All you need to do is measure the diameter of your router body and see if it meets the sizes quoted by the lift.
I agree completely about wanting a 1/2 collet.. It's also larger bearing and bigger motor
The other problem is that it's no longer that cheap, If I've spent £270 on the woodfan router lift and £320 on a new bosch 1617 router..
Or £400 on the JessEm Rout-R + router..
I'm currently thinking the best option might be to buy a cheap second-hand router and mount it to 8mm aluminium plate along with a ball screw and some linear bearings.. Inspired by JessEm Rout-R-Lift Prestige. With everything fastening to flat plates.
Looking at the picture below it doesn't look like they have even gone for linear beaings.
After a fair bit of research.... Please do your own research if your going to buy anything. I'm very happy to update if I have anything wrong..
Dewalt D26200 Compact Router – 900w
Collet System – 3-8mm, Includes 1/4" collet
Body Outer Diameter 69mm
Katsu Compact Router -710w
Body Outer Diameter 65mm
Makita RT0700CX4 Compact Router
Wood fan - Router lift for 89mm body router Product Code:WFNRL
Bosch 1617
1/4" and ½” collet
Body Outer Diameter 89mm
Dewalt 618 - £350
1/4" and ½” collet
