Im having a problem securing the 9x2 planks to the underside of the low coffee table. I used 200mm decking screws, counter sunk 3/4mm then covered with dowel. After the legs have been knocked about a few times they seem loose, I think the screw heads may be pulling through the table top.
Ive seen them advertised that they have used 12mm doweling straight through. Would this be secure if glue was used on the dowels also?
I need these to be secure, simple and nothing visible underneath if thats possible.
