PowerTool
Looks very nice
(although it must have been "pleasantly challenging" with all those sticky-out bits )
Well done =D>
Andrew
Well done =D>
Andrew
Paul.J":2vl09dnz said:Nice looking piece their Pete.
How did you manage do it.Looks tricky to me.
Looks like you've got a good finish on it too :? :?
Well done.
Paul.J.
Bodrighy":2i90emy6 said:...snip...
More importantly, SWMBO thinks it's great so it keeps me in her good books. She wants to keep this one. :lol:
TEP":2rm1ozlb said:Hi Pete.
Like your stuff, but if I had to choose the pot pourri bowl gets my vote.
You mentioned having a problem parting off the grass pot. If you have a old 1/2" firmer chisel grind the end into a parting tool shape, but angle the grind on one side as if you were grinding a skew onto the small cutting tip. You should end up with one short/one long edge on the cutting tip.
You can then part off with the slightly longer edge against the base of the piece and you should find it cuts a lot cleaner. Also you should always undercut the base slightly. It saves a lot on finish sanding.
Hope this helps!![]()
TEP":3flzya82 said:Hi Pete,
Just a follow on from my last, if you are that close to the chuck jaws use a thin parting tool. Or as I do a converted machine hacksaw blade, 30mm H x 1.5mm thick 325mm long,
Bodrighy":7scnumhi said:...snip...
I was focussing on getting the bowl thin (1 mil) and a nice thin stem. Chickened out on the stem when it started bending even with a very light cut
