J-G
It looks as if Phil has solved your problem -- the fact that the manufacturers told you 1 - that it was 6 x 1.5 and 2 - that they were available via eBay is most disconcerting!! or that the 'technician' that you spoke to has no idea what he/she is talking about.
I had little in the way of committment this morning so drew up a comparison of the threads in contention. --- incidentally the reference to ¼NPT (@Fergie 307 ) is way off track, That is an American Pipe thread (even forgeting the Taper part) which is 14.67mm dia. ---
This was drawn to show what the problems might be assuming that the existing hole was in fact 6 x 1.5. The green line is what would be left if you re-tapped to ¼BSW and the blue line if done at M7.
M7 taps are available from Tracey Tools who stock probably the widest range of taps & dies of any UK supplier -- no, they do not list 6 x 1.5.
