Philly
Hi All
Had a delivery from Maine the other day-number one goody was this....
It is a stright handled crosscut saw. I have the L-N dovetail saw which I really like but was intrigued by this one as to how it would compare and perform.
Here's a comparison photo to give you some idea of it's scale.
The blade is narrower than the D-S and is cut with 14ppi crosscut teeth. It has minimal set and the brass back is pretty narrow and thin. In use I had to check that it wasn't set up like a Japanese saw! The blade being so thin had the tendancy to bend if you give it too much welly. The 14ppi is quite coarse (compared to my Pax dovetail saw) but it is much easier to start the cut than my D-S. It cuts a finer kerf and tracks like a beauty.
Here is a (bad) pic of the kerf it leaves. The ones on the right are the crosscut, the fatter ones on the left are the L-N dovetail saw. I was amazed how easy it was to use and how true it cut. As you can see it is perfect for cutting "skinny pins"!
I was amazed by how well this saw works-it cuts quickly and accurately. It also lets the user know when it is happy-if you try and force the cut it chatters! Overall, this is the saw I recommend for fine work. It is a gem and reasonably priced ($80) This is definitely a well kept secret.
If you're in the market for a great saw get your hands on one of these!
cheers
Philly
cheers
Philly
