gidon
I have two sets of 6v cycle lights that run off lead acid batteries. I have tried both batteries (one is newer than the other) and after an overnight charge they are not working. This is the battery and connector:
I have measured the battery at the terminals and it measures 6v. And at the connector bit to the lights it also measures 6v. The bulbs aren't gone (I've checked the resistance across the terminal on the lights connector).
Has anyone got any ideas or know where I can get the battery connector (think maplin do the batteries) if that's the only option. The lights weren't cheap.
Thanks a lot
Gidon
Thanks a lot
Gidon
