Hello again, I'll probably be boring you lot talking about angle grinders, but some on a shoestring
might be interested.
Had my mind nearly made up, and was going to go for the Bosch in the local, but done some more investigation, and it turns out there might be quite a lot which look very similar , but could be very different.
The model is this one, GWS 750, and NOT the one which is shown in most demonstrations
which has the same model but also a few digits on the end.
I haven't looked into those, as I'm weighing up the local options first.
Looks pretty decent at first glance, but what I didn't cop, and I've even had a feel of the tool in the shop, was the plastic housing for the gears!
I found this video from a Russian chap and took a screenshot, he wasn't impressed with the lack of a coating on the windings of the Bosch, and pointed out the strange looking gearing compared to all others I've seen.
Seems a risk to me, and I'd have guessed that was what the first angle grinder was geared like, so seems a step backwards to me?
Not so keen on getting this tool now.
Might see if I can get a Metabo or something else for the same money, or just spring for a Makita,
although I must have a mess around with the one at the folks first.
That cap is not the only plastic part, the section in behind the metal case is also plastic, and that bit looks important and not something which could get melty,
The Metabo on the left was metal, and seems a better tool to me.
