One of my phones has a built in level app which is highly accurate, to make it a long level , I lay the phone on a long rigid straight edge.
My brother has that on his phone, we tested it again a laser and it was dead level.... i was quite suprisedOne of my phones has a built in level app which is highly accurate, to make it a long level , I lay the phone on a long rigid straight edge.
looks like you can by using one of these DWL-130 | Digital Level Module | Digi-PasWhat would be nice is a set of levels that you could swap the digital part so you get a set of levels without spending a fortune
Measure out from adjacent walls and align laser to your marks. Lasers only deal in straight and level lines not squareness. If you need just lines you can, as in most lasers, switch to non levelling stationary mode. Handy for diagonals etc.I now have a laser level, went for the Stabila and also a Huepar multiline laser on @MikeK 's recomendations.
Here is a question, you get a nice horizontal line all round the room because the level is self leveling, you get a vertical line up the wall across the ceiling then down the opposite wall and back across the floor but here is my problem. The lines up the walls are vertical and on opposite walls but not neccessarily square to the wall and so if you put a stud wall from one line to the other then that wall need not be square to the room so any fixes that I am overlooking or anything I have not understood here ?
