Ive got a dewalt cross line in red... ok inside but useless outside in daylight. I then bought a 3 line green dewalt as its advertised as 50x brighter.
It turns out 50 times brighter than something you cant see isnt all that great
![🤣 🤣](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f923.png)
![😆 😆](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f606.png)
You can go about 4m in bright light, outside, beyond that you need the little laser detector.
I use mine a fair bit, occasionally both. If you have 2 reference marks, you can ping a level line round a room for a studwall in seconds.
Awesome on a tripod and left set up in a kitchen fit or for tiling, etc.
In a loft conversion I've just done, i marked the intended pad heights for steels etc, set the laser and simply put a load of level marks around in the appropriate places, worked perfectly over 14m in a dark loft, extremely quick.
I set the walls using the laser, it was so darned good that all the linings had a perfect 3mm consistent lip for plaster once the plasterboard was on.
I cant find any photos of the green laser. Neither of mine have a gyro lock, so they always go for level and flash if they cant achieve level at the angle of the unit
