tonysuffolk
New member
does one machine do both ? if i get a laser cutter will i be able to etch/engrave onto wooden surfaces
Tony
Tony
A rotary will only work if your walking stick is a perfectly straight cylinder, which I suspect it won't be. There are also size constraints to bear in mind, most desktop lasers have a maximum working length of 400mm. Have you thought about a pyrographic pen - I think that's what they're called.Hi Thanks for your reply's what i want to do is to etch a pattern/design onto a walking stick that i made so i need to have something with a device to turn the stick as it etches. Is this even possible.
Tony
