Mr G wrote:
"crude but effective" seems to be the general rule for anything out of sight
Don't agree here at all Mr G I'm afeared. In my view the satisfaction comes from making
all parts of the job as good as you can possibly do them
without cutting corners at the expense of time or sometimes money. As an amateur maker that is a luxury that I can afford but will concede that different constraints
may apply if you have to earn a crust from making sawdust.
I am building my elm cabinet this winter and recently finished doing the back, solid elm frame with two floating elm panels. This has been niggling me for some time - I didn't do it in
quite the right way and had I fitted it to the cabinet later on (and it would be against a wall where no one will see it)
I would always know that it was rubbish and it would irritate me....I would have always been looking at the back and thinking ...Hmmm. Consequently the finished and polished panel went thru' the bandsaw the other night and I have prepared some new timber which is adjusting in the 'shop.
When I was working in the trade, my then boss made a piece for David Linley which was then inspected at length by one of his minions. Now Dick had used some ordinary 75mm pozidrive screws in the construction, thinking that they wouldn't be seen, which were buried deep on the underside of the piece..nothing wrong with that. Linleys bloke looked underneath and said that when the next piece made it would be using... 'proper brass countersunk screws, with the heads mirror polished'... Dicky just mumbled something in the affirmative and turned a little bit pale
:shock:
As JK has said in one of his books, its as easy to do a job correctly ( and he was talking about back panel construction) and to your satisfaction as do it badly - Rob
