scholar
I am making a new drill press table and matching worktop for the cabinet beneath. I have some Formica that I plan to use for the tops and I have made up two bases, each a lamination of 25mm mdf and ¼” birch ply (just some old stuff I had hanging around). The edges will be lipped.
The mdf and birch ply were clamped up flat when glued and I was thinking that when completed the top layer of Formica would balance out the unequal laminations beneath. I made these up ages ago and it seemed that the bases had not warped; however, now I want to get round to fixing the Formica, the whole thing has curled up somewhat, so I am just thinking what to do.
Options seem to be:
- clamp the base flat by bolting to a flat framework/cauls from underneath, before gluing the Formica
- relieve the birch ply with a criss-cross of saw kerfs and hope the base comes back to flat before gluing the Formica
- junk it and start again, possibly 2 x 18mm birch ply (my last little piece that I was keeping as my pension) - but then would I need to add a bottom layer of something to balance the Formica?
I suppose an underlying question is do you need to balance a Formica top layer on anything?
Here is a picture
Options seem to be:
Here is a picture
