Kity bandsaw wont rip straight
Andy Pullen
7 Apr 2007
Kettering Northants
I have been having problems getting my Kity 613 bandsaw to rip timber without running off badly, even after careful setting up and was wondering if anyone has any ideas what might work. I am using 1" 3tpi blades but am now thinking maybe they are at fault as the set up has been meticulously carried out ( as much as i know how to and after much study). Your thoughts are appreciated. Regards Andy
Hi Andy
Welcome :)
We need to know which blades you are using as this can be a big problem ( if you are using poor blades ).
Also try to check to see if the set (how much the teeth stick out out on both sides of the blade, if you dont know ) on the blade is the same on both sides or have you used the blade for cutting curves.
I hope it helps
Regards Colin
The blades came from a well known source that advertises in woodwork magazines, but i got them at a show and they are the silver type rather than the blued steel ones. I was wondering wether one of these tipped resaw blades might makwe a difference but at about 50 quiod each it's a bit of a gamble. I have actually gone over the teeth with a round diamond file to make sure they were sharp but it doesn't seem to have made much difference, maybe i need a saw set. Cheers Andy.
Hi Andy,
Welcome to the forum.:D
I may be teaching you to suck eggs, but have you set the fence square to the table and the blade is trying to wander from a parallel cut to it, or have allowed for the drift of that blade? :-k
Many blades have a bias to one side, test by marking a line down the middle of a bit of 2x1, about 2' long. Free hand cut to this line, half way along the timber, stop the saw and compare the angle of the timber with the line of your fence. My EB315 has three screws at the point where it fits on to the slider, these allow the angle of the fence to be adjusted to correct for blade drift.
As Colin asked, have you cut curves with the blade? Once used for cutting curves the blade will not cut a consistent straight line as well as it did before cutting the curve. :?
I have checked for drift but it seems to go where ever takes its fancy, even freehand makes no difference. I haven't used the blades for cutting curves as they are too wide for that at 1" but i can understand how the set may be affected by this. It can cut straight sometimes if not too demanding but once it decides to wander there is no stopping it. Regards Andy
Hi Andy,
Could be a number of things causing the problem you described.
One of the first things to check is probably the blade tension, particularly on a 1" blade which is difficult to tension adequately on smaller machines.
With top blade guides at their highest setting there should be no more than around 5mm deflection in either direction from vertical if tensioned sufficiently.
Let us know about that and then we can work through the possibilities one by one.......
Cheers, Paul. :D
Not clear from your post whether the blade wanders all over the place, or whether it just leads to one side or the other. If it wanders, then could it be the tension is too low? One other thought - is the 613 designed to take 1 inch blades? I thought when I had one that it would only take up to 3/4inch.
Also not much consolation, but I could never get my 613 set up reliably. :(
Hiya paul, with the guides fully opened i have maybe 6mm total deflection though it can twist more than that. Typically it just did a couple of perfect 3mm rips in 60mm pine a metre long, but needs to be predictable for important jobs. it seems to end up jamming the timber between the blade and fence as the blade moves away and creates a wedge shaped piece, then the blade is fighting to straighten itself. Maybe i am using too big a blade. I am still wondering if they have adequate set. Regards Andy
I have a 613 an get good results when ripping with a 1/2 inch 4tpi skip tooth from Axminster. I tend to rip freehand and then push the wood through the thicknesser. I would have thought a 1 inch blade would be too wide. I dont have a table saw so my bandsaw, RAS, thicknesser combination form the hub of my workshop.
Sounds like the tension is okay then.
Try DaveL's suggestion for setting the fence, should make a difference, and needs to be redone whenever you change the blade as all blades cut differently.
Have the upper guides lowered to just above the timber height also when cutting, and don't force the wood through too fast.
If all that doesn't work then you may need to try a "point" fence, more on that later after breakfast !
Cheers, Paul. :D
I have been trying to reseach the spec fior the Kity 613.
Blade size for such a modest machine seems to be capped at 1/2 inch or 13 mm. See your manual or find one on the internet.
You are using a blade which is too big for the bandsaw. A 1 inch blade would be almost impossible to tension properly on such a small bandsaw. In fact to get proper tension on the blade would probably buckle the pressed steel frame.
Try a smaller blade size. You should be able to rip with a 1/2 inch blade just as well as with a 1 inch.
regards
alan
Cheers Alan, I recall the manual said a 20mm blade was the max but it will physically take a 1" comfortably with sufficient tension. I was advised that the issue with the wider blades was the thickness of the steel folding around the smaller band wheels if anything. The Kity has a substantial steel tube that supports the tension on the blades and isn't just metal pressings like some others. I am still leaning towards tooth set on the blades and am thinking of getting a setting device from a merchants today. regards Andy
My advice would be to give the guys at Dure Edge a call and place an order for 1/2 or 3/4 inch blade and then compare the results. You'll need to setup the drift compensation as Dave has already mentioned, but this will give you something to compare too. I think personally, you're not getting enough tension on the 1" blade and/or it's a poor quality one.
My own bandsaw was a completely different beast with Dure-Edge, I could re-saw almost anything I threw at it with superb results.
Just because it will accommodate at 25mm blade it doesn't mean to say it will tension that blade adequately. Experience tells me that to tension a 25mm blade you need the sort of frame rigidity that only comes with a 500 or 600mm wheel fabricated steel saw (or a cast-iron frame machine) - something the 613 clearly isn't. Therefore the machine is simply incapable of tensioning that blade adequately. Period. I'd suggest that you go the other way and install a thinner 1/2in blade, preferably a hook tooth form blade from a good quality supplier such as Dure-Edge or Dragon and try again, this time with a point fence to overcome the drift which is more inevitable in narrower blades.
Then I'd say you were wrongly advised. The issue is that a machine with smaller wheels runs a much shorter blade than one with bigger wheels and those blades are being "bent and unbent" around a much tighter radius wheel many more times in every hour's running, e.g. the weld on a 3 metre or less blade on a 14in saw will need to go round the wheels twice as often in every hour as the 6 metre blade on a 20in wheel bandsaw. Ergo weld failures happen earlier on smaller wheeled bandsaws because the number of bending actions and the severity of the bending are so much greater. My experience with bigger bandsaws is that you're more likely wear out a 3/8in or wider blade than to break it prematurely, whilst on 12 and 14in machines the converse is truer.
The frame still isn't all that rigid, though. Most blade stock manufacturers recommend somewhere going for around 15,000 to 20,000 psi blade tension (a measurement of beam strength) for carbon steel (black) blades.
Beam strength is the blade's ability to resist deflection. It is achieved by combining several factors: correct blade pitch, blade width and blade guide settings. A key factor in achieving beam strength is applying the maximum blade tension that the blade manufacturer recommends. Because resawing hardwood places is so demanding of the blade if the blade tension is inadequate, the blade will bow (vertically) in cut and can even start to snake - the sort of behaviour you seem to be describing.
I have a Starrett tension gauge (necessary on large saws as they have the strength to pull blades apart if you get too gung ho) and I can tell you that my old Startrite 352 saw could manage about 12,000 psi on a thin 1/2in carbon steel blade, but only 9,500 psi on a similar thickness 3/4in Starrett carbon steel blade. Needless to say befoe I got the Aggy I used to resaw using 1/2in blades on the Startrite and live with the almost inevitable blade drift. By way of comparison I can pull more than 25,000 psi with a 3/4in carbon steel blade with my 700mm (28in) Agazanni like this:
and can top 20.000 psi with a thicker-bodied Lenox 1-1/4in TCT resawing blade - a figure which my smaller cast-iron frame machine can't quite match, mainly because the tension spring needs to be retempered. Assuming that your 25mm blade is thicker than a 1/2in blade, which it probably will be especially if it is a bimetallic blade, then you stand no chance at all of reaching adequate tension on the Kity. Either the tension spring will compress fully or the frame will flex long before you achieve the required tension.
A note here for anyone tensioning blades for resawing - at the end of a session I was always advised to drop the blade tension with fabricated (i.e. steel frame) bandsaws to avoid running the risk of warping the frame or simply compresiing the tension spring permanently.
Scrit
Well Andy....one has to presume the manufacturer knows what they are talking about when their manual states 20mm max blade. It is doubtful that you are getting enough tension on the 1" blade. Furthermore even if you do manage to get enough tension you will eventually knock the bearings out of the machine because they will only be rated for the manual max. I have no difficulty getting a nice cut with a 1/2" silicone steel blade on my Delta 14" BS resawing 8" hard maple.
Lee
