Kity 636 planer/thicknesser manual & parts list?
No manual, sorry, but the user manuals aren't a huge amount of use anyway. Hunt online, you might be lucky.
Extraction hoods can be made from sheet steel (or alu) if you have some tinsnips, a file and a pop riveter - or you can use plywood (except for the spout!) ...
Look at pics of over-unders to get some ideas.
The surfacing guard should be adjustable for both height and lateral projection across the tables.
An optional surfacing extraction hood can rest on the thicknesser bed. If you dimension it correctly, winding up the bed can secure it in place. It might do double duty as a thicknessing extraction hood, secured by an alternative method.
The simplest form of thicknessing guard / hood takes the form of a chute, but sprays out dust & chips all over.
All the measurements can be taken off the machine.
3636 kity
Yes, I got that.
It's likely that a thicknesser hood (whether a plain chute or one with an extraction spout) would attach instead of the fence - ie would have a clamping bar that replicates the fence bar. Apart from that it'll be just a shaped box. So you'd need to make a bar accordingly, and bracket the hood to it. Some form of registering would be handy so the cutters can't hit the underside of the box anywhere.
