quintain
My 20+ yr old kity 613 bandsaw is having an infrequent blade change.
It is a very good machine for my limited use; genrerally max 2" (50mm) stock with mostly straightish and slight curved runs.
I have today fitted a 3/4" (20mm?) 4 TPI blade.
The new blade runs on the top wheel with the angled cutters just proud of the front of the top wheel' as per Kity's unusual setup.
I am reasonably aware of how to tension the blade; I use the " wobble test" where no top or bottom guides are in use; I also know how to adjust the angle of the top wheel to put the cutters just ovehanging the front of the top wheel.
I check and check again after every blade tensionning or angle adjustment that all is correct on the top wheel. i.e rotate the top wheel many times by hand and then (pray, have another coffee) and switch it on
BUT
The blade runs on the lower wheel with the angled cutters more into the middle of the wheel i.e. NOT overhanging the front wheel edge.
Question:
1. Is the location of the blade on the lower wheel important
Best Regards
Richard
BUT
Question:
Best Regards
Richard
