Doug71
I'm fitting a kitchen, not my normal work, it's a bit of a favour for someone and some opinions would be appreciated.
There is an integrated washer/dryer next to an integrated dishwasher with a panel between them. What is the best way to fit this panel, do I put it in before the worktops and use some laths 600 and 450 long to hold it in place till I can fix it to the worktop or do I just leave the correct gap and fit it under the worktop after when I have something to bracket it to?
Here is a quick sketch showing the layout and panels.
Would it be better to also have a panel going to the floor on the right of the dishwasher, the plan doesn't show one and they haven't sent one?
Is this the best way to do the plinths, I presume the one under the washer/dryer might need to come off sometimes which is why it's separate? The plans show the panels going to the floor which is fine as the flooring is Karndean and already down.
Any advice appreciated, @Distinterior is normally my guru for these things.
