woodbloke
Damian - not sure, I'd suggest you send Matthew a PM - RobIronballs":h037l3o0 said:Rob - do you know if Matthew has access to adhesive backed abrasive paper in the ranges 200-2000 grit?
woodbloke":27r3kcoq said:sandpaper it definitely ain't..if you want to polish the mirrors in the Hubble telescope then this might be the stuff you're looking for - Rob
:lol: :lol: - RobJake":162nwnah said:I hope you manage to avoid the need to send up a shuttle with corrective optics for your blades.
For me it's clunky...physically too big. You also need to buy extras to do other things (cambered blades, skewed blades and small blades) but the worst reason for me is that the roller runs on the honing material and there's not really a way round that (you can build a runway behind but this doesn't really solve the problem as the blade edge to roller distance is too small, hence you can't use the full length of the honing medium). The blade registers from the wrong side and it clamps from the top, which logically to me seems wrong.
Derek - without getting into a slanging match regarding the merits of the KIII vs the VMkII, the KIII for me, personally, is infinitely preferable to the Veritas. You mention the KI...I'm discussing here the KIII which is a totally different animal and will doesn't run on the honing material, something that I specifically required in a gauge...however you slice it, any gauge with a trailing roller has to run on the stone and if its a waterstone :shock:For me it's clunky...physically too big. You also need to buy extras to do other things (cambered blades, skewed blades and small blades) but the worst reason for me is that the roller runs on the honing material and there's not really a way round that (you can build a runway behind but this doesn't really solve the problem as the blade edge to roller distance is too small, hence you can't use the full length of the honing medium). The blade registers from the wrong side and it clamps from the top, which logically to me seems wrong.
I'm sorry Rob, but none of this flies for me. Maybe for you, but your statement has all the properties of a general critique, which demands a response in the name of objectivity.
Note that I have the Kell #1, which I use for my oval bolstered chisels as it is side-clamping, a preference for such thick blades. Also note that I prefer to freehand my blades - chisels and plane blades - that do not require a secondary bevel. For the latter I use the Veritas mk II. And also note that I was involved in the pre-production testing of the Veritas, which may bias me. Still, I have a number of guides and I see them all having specific strengths and weaknesses (which is why I have them all).
Could the Veritas Mk II be less clunky? Sure. But what you have in the Kell #3 is the most clunky set up I have ever seen! The reason the Veritas appears clunky is that it is made of two parts, the angle setter and the guide. The guide alone is quite compact - and it is comfortable to use. The Kell #1 is the most uncomfortable guide ever. I only use it because it can take the depth. Is the #3 the same as the #1 in this regard?
You criticise that the Veritas for the add-ons. This is to keep the price down of the basic unit. Buy what you need. This way you can have maximum flexibility. Still, are you aware that the basic Kell #3 is 20% more expensive than the basic Veritas mk II? http://www.fine-tools.com/hilf.htm
You don't like the fact that "the roller runs on the honing material"? A news flash - the Kell also does when I use waterstones.
"The blade registers from the wrong side" ...!!!! Do you have any idea how important this design feature is? You could not have an integral angle setter without the blade this way round. Blades come in different thicknesses and this is the only way to accurately set the bevel angle using an integral angle setter. The integral angle setter is part of a bigger picture - the guide is also designed to use the skew setter in a similar way.
Can the Veritas be improved? Absolutely. Would I swap it for the Kell #3 which will require a drawer of bits-and-pieces. Not on your Nelly!
Regards from Perth
Derek
a stoic but boneheaded rottweiler
You have deftly misunderstood every element of what Rob is saying
I've been after a single honing guide (note Paul ) that will hone almost (pig stickers excepted) anything, simply and easily.
and eloquently defended the Veritas Mk2 against everything except the Kell No.3 Mk2 that the thread is about, and arrived firmly and with notable indignation back at the party line!
matthewwh":2ck5fcyv said:Fair enough Derek, I didn't think it sounded like your usual measured and considered tone. Apologies for tearing a strip off you. OK, now that we've all put our handbags away and agreed to play nicely.......
I think there are some elements of Richard's design that are both simple and very clever. Some of which could have been incorporated into the Veritas, or could be incorporated into a third generation if they ever decide to do one.
The wedge squeezes against a bar - in effect a fulcrum, so the wedged side is free to rotate about this axis, allowing the guide to accommodate tapered blades whilst always maintaing the back as a referance face. I think Veritas could incorporate this principle by allowing the surface that grips the face to pivot in some way.
Having a pair of rollers running outside the blade was originally intended to maximise stability. A pair of wheels set broader than the blade will dictate squareness to the edge rather than following a pre-existing condition. This guide was always intended to function as a fixture, rather than merely an angle stop for freehand honing.
The Kell No.3 Mk.2 is a facilitator of imaginitive use rather than a prescriptive solution - as Rob has demonstrated, the application of a little lateral thinking goes a long way. In three weeks he has developed all sorts of new ways of using it and covered his individual needs. I was happy with two wedges, one for plane irons, a smaller one for chisels down to about 3/4", and four lines cut into the top of my front vice for setting projections. Whilst Rob and I were chatting he suggested that a narrow wedge would work better for narrow chisels, so I chopped a bit off the end of the smaller one and we tried it, so I now have three wedges and can hone chisels down to 1/4" width.
With my retailers hat on, I'd love to see a range of accessories, a pack of assorted wedges and shims for different applications, but I know if I did get them manufactured and put them on the market a lot of people would say 'sod that, I can make my own' and with my woodworking hat on I'd be one of them. Catch 22, but who knows, if the mood takes me I might do it anyway, possibly another reason to get a few boards of Kauri impregnated with resin....?
For the benefit of anyone who is confused, the original No.3 had a sprung pin that would provide the right setting for LN skew blades. This made it difficult and expensive to produce and was only of benefit to a small number of users. It was omitted on the Mk.2 version, which brought the price down and as Rob's explanation demonstrates, you can still hone skewed blades of any angle you like.
Aled - I use paraffin which is fine. The blade from 'Big Woddie' is a Phillyspecial and is 6mm thick...goes under the bar without a problem. If it didn't fit though, I'd just knock up a specific wedge for it - RobAled Dafis":3g1qv5bz said:Rob / Matthew
What lubricant do you use with these papers? Does it matter? I currently use WD40 on diamonds, smells good and helps keep the dreaded rust at bay.
Also, will the Kell #3 Mk 2 accept a 6mm :shock: plane iron?
Aled
I've tried several but find water seems to give the best cutting rate and finish; at least on my bog standard chisels/blades.Aled Dafis":3ekw4wou said:Rob / Matthew
Aled
woodbloke":ro0qhq96 said:but the worst reason for me is that the roller runs on the honing material and there's not really a way round that
