woodbloke
Boz - quite correct...you can have a coupla three tonight as well then :lol: - RobBoz62":1py75t30 said:Just to correct the correction :shock:.
The wheel axle axis is centred on the main brass plate in the Kell 3 ie it is all symmetrical. So the registration pins can go either side - you just reverse it before inserting the blade. Any projection setting jigs will still work the same.
And a fine piece of kit it is too.
Boz
