siggy_7
Full time tool collector, part time woodworker
Now that I finally have a dedicated workshop, I am getting my act together to sort out the windows on our house (by which I mean make some better ones). I have recently bought a second-hand Hammer F3 spindle moulder to hopefully make a decent job of it. I think I have got my head around most aspects, however the bit that I have options on which will determine tooling is the design of the mortice and tenon joints. There seem to be a few different ways this is approached:
Using a single open tenon joint would be preferable from the perspective of having less tooling/setup and minimal need for additional tool purchase. Mainly though I am interested in views/experience on the relative strength of the finished joints. I presume on the frame it makes less of a difference since the sections are larger and the frame is secured in the opening anyway, so the joint isn't doing that much. But on the casements I can see there is relatively little material in the joints at the corners of the frame once all the rebates have been made (I'm looking to make storm-proof casements so rebates on both sides of the frame) so the joint choice is a bit more critical. My concern is driven at least in part by my current windows, which have some badly warped casements (approaching 1" gaps to the frame in places). I am planning to use accoya for stability and longevity.
Whichever option I go down, I will be intending to use power tools/machinery. Some people love perfecting their hand woodworking skills and chopping out mortices by hand - if this is you then I admire your talents but I am not that way inclined. I would prefer to stick mainly with tooling for the spindle moulder, as I already have that, rather than having to buy additional machinery - but if it makes a big difference to the finished article then I'm prepared to explore that.
All advice and experience gratefully received!
- Single open mortice and tenon - I have seen these in some of the dedicated window tooling used for the frames
- Double open mortice and tenon - this is what most of the dedicated window tooling seems to use for the casements and for some of them also the frames
- Single haunched/franked mortice and tenon - this is the way most traditional window makers seem to go
- Single/double loose mortice and tenon - such as the Fry router system uses, or if using a Domino
