skipdiver
I need to join some ali tube and would welcome suggestions as to the best way to approach this as i am a novice in all things metal. The join can be permanently fixed one side but needs to be detachable the other. I was thinking of plastic tube joiners, which you can buy with metal inserts for strength but i can only track down one company that does the size i require and they will only sell me 700 at a pound each, so that rules them out.
My preferred option is a piece of tube inside the main tube, i think it's known as a splice from what i can gather. The guy who fabricates them for me now uses this method but the piece he uses to join them has clearly been turned down on a lathe to a snug fit and i don't have that facility. The tube in question is 1 3/8" diameter 16g, which is 34.9mm OD and the inside diameter is something like 31.6mm. I have some 1 1/4" tube and it is a tad too big to slide inside, so the next option is 30mm OD, which i think may be a tad too sloppy. Is there any way i can slightly increase the OD with some kind of tape or shrink sleeving maybe? Alternatively, is there an easy way to slightly reduce the OD of the 1 1/4" without a lathe.
I have been frantically googling for days and am none the wiser as metalwork is a steep learning curve for me. Any help most gratefully received.
