Another way would be to use emery tape on the larger alloy tube in a strop fashion (a long length of emery held in each hand and pull it alternatively and take it down to near the ID size of the other tube).
Loktite do a mix that you put on one or the other, or both, it goes off in seconds like all loktite, no ait it goes off. You will not pull the inner tube out of the bigger one believe me.
I cant remember the loktite number but it's easily available. I got two washers put a couple of blobs on one washer dropped the other on top, squeezed the two washers together and they were one. I could not get them apart, in the end i used a knife and hammered it between the washers, then they came apart lol.
Not all alloy is soft some is very hard, we had Dural and it was very hard indeed. There are also aircraft specs as well but they will be expensive.
