jewellery box
T.allan
31 Jan 2008
Co Durham
whats the best and simplest way to round of a lid (as opposed to being flat) about 8" X 3" on the top of a jewellery box?
laminate over a former or coopering. In fact as its so small you could just shape it from the solid with the inside being left flat or concave.
Jason
If you mean chamfering the edges with a half-round section, then the quickest way is with a router and bearing-guided roundover cutter.
I would use a sharp block-plane though, finished with sanding. (One of the few times I use abrasive paper.)
I'd also use a plane if I was making a thick top into a 'treasure-chest' type lid. I find the best way is to cooper it and make it curved to begin with, but if you're fussy about finish you need a rounded sole plane or spokeshave to clean up the inside.
Best of luck..
:D
If you're on about doing a rounded/domed top then I'm planning something similar myself. Depending on degree of curve will either be bandsaw and plane or straight to plane, spokeshaves very handy here and I think I'll be using the flat bottomed one
