JET JPT310
fouroaks
New member
27 Feb 2009
Hi All,
Anyone own one of these, can it cope with 10inch oak boards??
i think the 310 signifies 310mm, if so then yes.
simplest thing to do would be to check jet's u.s. website, spec will be in inches
fouroaks":xfv90uml said:
Hi All,
Hi Fouroaks
Yes, and er....yes!
Hi Guys,
Thanks for pointing out that its a 12" PT (I guess its in the name PT310 doh!). What I mean is will it cope with wide oak boards. Does it have the 'oomph' or will it grind to a halt unless only taking off 1mm a pass??
Cheers :lol:
I have the 10" version and it doesn't even sigh when I pass a 10" board over or under it.
The 310 is built sturdier and I'm positive it could take anything you throw at it.
Only you pay now a little more for your Planer/Thicknesser from JET.
It is the same Planer/Thicknesser the hat on stock at Axminster but now you pay about 20% more.
Maybe it is better to look for a other brand.
