I still think the problem is they have removed the locking lever, which I recon would not be too difficult to retro fit.
The lowering and lifting mech uses bevel gears that will bounce off one another and cause movement, someone said it uses worm drive but from the drawings it's clear it doesn't use.
I can't see what the fuss is about, I have a fox p/t and I managed to get that to cut within 0.1mm over the full width and it will repeat the size all day.
If you want Tom I'll do you a swap? :lol:
