Jet 16-32 Drum Sander
murphy
UKW Supporter
7 Feb 2012
London
I have a Jet 16-32 Drum Sander and it has worked fine for years but lately it bogs down with slight pressure, I have always taken very light passes as I know it is not a thicknesser, but now all but the lightest pass and it stops mid way through the length, I have tried to see what is at fault but it is difficult to see, I have removed the drum and checked the large coupler which is tight on the motor shaft and the drum, both have a keyway which the grubscrew tightens down on so there is no slipage there, I wonder if the main motor is knackered, that is all I can think of, unless someone can suggest something else to try
It’s definitely the drum stalling, not the power feed belt?
Might be worth checking the cap(s) on the motor. My 22-44 version has a cap-start cap-run motor. If yours is the same, it might lack torque if the run cap has gone.
Where can I get a new Capacitor, does it need to be ordered from Toolfrance, the part no. is JWDS1632-154SC the motor is shown in the parts list but not the Capacitor, just the part number
Does the cap have the capacitance in microfarads (uF) and the voltage written upon it? If so you can buy it from any reputable electronic distributor eg. RS Components, Farnell/CPC, etc or you can get them through the long river or E buy gum! But the quality may be questionable.
Martin
Thanks Martin
I have emailed the Toolfrance outlet in Rugby UK to see if the have any in stock, as you said other brands might be cheaper but lower quality, I don't suppose a capacitor is very expensive anyway
I’d be (pleasantly) surprised if the tool merchant would supply you with a new cap.
Did your electrician mate have a look? Caps are pretty easy to test. He’d probably have more luck ordering you a new one if needed. Otherwise, just post the details on here and we’ll find you one.
Unplug the machine and find the two caps under rounded covers on the motor. Assuming it has two, like mine does.
You can have a look - sometimes a failed one will have split and splurged its contents out.
A meter with capacitance test function is really needed. Discharge with an insulated screwdriver across the terminals, disconnect from motor and see if it matches the value written on there. Note the specs while you’re at it, and post here.
With a basic meter, you could try measuring resistance one way (should count up to overlimit), then swap leads (should go negative, count up past zero to overlimit again). Very basic test but would identify a dead short or open cap.
One quick test I forgot - turn the motor on briefly, then off. Listen for a click as it spins down. This tells you the centrifugal switch is at least partly working.
