thetyreman
does this look like lime plaster to you?
the top layer looks sort of white with what looks like bits of gray ish aggregate inside, the yellow colour might be pigment or the original wall colour,
I recently wanted to remove old artex from a wall, and have come to the conclusion it's way less work just plastering over it, how would I know that the plaster is lime or not? it doesn't have the typical pink ish look that you normally see and could very well be the original late 1930s plaster, it's also weird that there's no plasterboard underneath, which is what made me suspect it could be lime...
The actual artex layer is much much thinner than I realised, in parts 1-2mm, so I recon it wouldn't need a thick layer, and I was thinking of doing it with traditional lime plaster instead of modern gypsum based stuff,
thoughts?
regards,
Ben.
thoughts?
regards,
Ben.
