John Hall
Can you grip them with mole grips?
No, as there is a countersunk head that is sunk in the metal hardware. Nothing is protruding over the wood level.Can you grip them with mole grips?
Hole saw usually requires centering drill bit so that it does not dance around when starting the hole. How is this maintainted when there is the original screw just in the center.
Hello,
I am now disassembling my great grandfather's workbench made from oak. I need to replace some boards on it and I have found that there are many nails in the workbench, that were probably added later for holding things together by my granddad.
There are some flathead screws that are holding vice hardware and the wood is so dense that I have no chance to unscrew them without spoiling the flat head.
Also I have one nail that I am unable to beat out from the other side. The wood would break sooner than it would eject the head out of when beating the tip with a hammer.
Is there any trick that would soften the wood around a screw/nail so that it can be unscrewed/pulled out more easily? Would steam help here?
Thank you.
I have finally cut 14 mm holes with a hole saw from the opposite side halfway deep and banged out the remaining screw with a punch. Now I will buy a countersunk metric bolts with big washers that will cover the holes (as I have a 10 mm thick stainless steel dowel plate and it would be a chore to drill 14 mm hole into it with a cordless hand drill)Where there’s a will there’s a way
Organ builders often have this problem and heat the screw with a powerful soldering iron before trying to tighten it to get it moving. Mild steel screws can react with oak, so good luck! RichardHello,
Thank you.
Whenever I need to get a difficult nail out with minimal damage I usually reach for my Slide Hammer Nail Puller. If you haven't seen or used one before the video below shows it's operation;
Once you've driven the jaws in to get a hold of the nail head you can exert a lot of leverage to pull the nail out easily. It's surprisingly effective in practice. Have pulled some big nails out of both hardwood and softwood.
This was the one I bought from Amazon a few years back;
https://www.amazon.co.uk/gp/product/B001CKAR4Q/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
Great outcome. Stainless should last a lifetime. When I put my bench together in 1975 (15 at school), my father showed me how to coat the mild steel screws using a bar of soap to prevent rust. I moved the bench last year and had to remove these screws from the apron that had sat in a dampish stable for 46 years, not easy but they came out with careful screwing and unscrewing. My Dad is now 90 and rather forgetful, but I'll always remember that tip. Stainless steel has made it redundant. Many old workers used tallow on the steel to preserve it and lubricate the hole. I still do this with cheaper yellow screws.I have finally cut 14 mm holes with a hole saw from the opposite side halfway deep and banged out the remaining screw with a punch. Now I will buy a countersunk metric bolts with big washers that will cover the holes (as I have a 10 mm thick stainless steel dowel plate and it would be a chore to drill 14 mm hole into it with a cordless hand drill)
The Rockler screw extractors are fiendishly expensive, if you can find them in the UK. I’ve tried using a diamond grit tile drill, which sort-of works, but makes plenty of smoke! I also found theseThe American store Rockler sell a nifty screw extractor. It simply removes a plug of wood around the screw and then you can use a molegrips to twist the screw out. It works a treat although maximum size is only 3/8 " Replace it with a glued dowel which is absolutely fine for inserting new screws.
Try heating the screws with a big soldering iron (80watts +) That sometimes works to break the bond.Hello,
Thank you.
You should first try to turn the screw clockwise half a turn before you try to take the screw out, that usually works.I have tried the extractor but the screw heads just snapped off. So I need to use the plug cutter to cut around the screws.
Here is the failed attempt with the extractorView attachment 131660
Here is another female part from the vice screw that I need to unmount
Here is the back side
Probably I will buy a new 50 mm oak board and replace all those old wooden parts where the hardware was, so I will just remove the hardware from the wood and do not care about the leftover holes.
