It's good to rambleBenchwayze":3uy624a4 said:I'm rambling on! Sorry! :mrgreen:
I'm no turner but I've found it reasonably easy to turn 18 inch lengths of dowel down to half inch or so. I made a good few lengths in oak when I made some Mackintosh chairs. I took my time and they came out fine. I did try a Veritas dowel maker but quite honestly they were better from the lathe. Probably me but I couldn't get a really smooth finish (it left tiny ridges) from the Veritas without some sanding - and I hate sanding :?marcros":2rkgtfmp said:it is a shame that one couldnt be made with an adjustable blade, and an adjustable hole in the end. That way, you could produce whatever dowel you wanted on a single plane.
RogerP":3gncvyue said:I'm no turner but I've found it reasonably easy to turn 18 inch lengths of dowel down to half inch or so. I made a good few lengths in oak when I made some Mackintosh chairs. I took my time and they came out fine. I did try a Veritas dowel maker but quite honestly they were better from the lathe. Probably me but I couldn't get a really smooth finish (it left tiny ridges) from the Veritas without some sanding - and I hate sanding :?marcros":3gncvyue said:it is a shame that one couldnt be made with an adjustable blade, and an adjustable hole in the end. That way, you could produce whatever dowel you wanted on a single plane.
Ives":6srk0qcm said:I'm having trouble finding them. I need them 18mm in maple and or beech. The best timberyard I know says they have them in ....can't remember the name but starts with r
dickm":16owvm8k said:Needed some dowel for a repair job today, didn't have any of the right size, so had a quick look in the metal bin for something to make a dowel plate. There was a piece of very agricultural looking steel with two holes of approximately the right size, so tried bashing some oak through them. Came out about .5 mm too big for the job, so was just going to drill new holes. Thought it might be worth trying peening the edges of the hole with a hammer to make it smaller; bingo, it worked. A lot easier than drilling another hole in 3/4" plate!
Almost certainly not an original idea but it might help someone.
