Don’t know your facilities or set up Sammy, but if space is limited and large sheets are too big to handle successfully on the table saw, it’s better to take the tool to the work. I made a dismantlable frame that rests on a couple of workmates outside and use a tracksaw and 2.7m rail. It’s brilliant and the cut is better than my table saw with its expensive blade, just because there is no deviation which I tend to get with large pieces on the table saw. I steered clear of joining rails, as it introduces the possibility for error.Hi
I’m debating whether I should invest in a full size rail meaning 2.6m or 3m
I will be making a bunch of cabinets soon and will need to rip long lengths of MRMDF for door rails and stiles
I like the idea of just putting one rail on and not worrying if it’s straight
BUT!
I’ve heard that you still get some deflection in the track because it’s so long, which defeats the purpose. I might as well join two 1.4m tracks and have less hassle storing them.
I’m either going to get a Makita 3m rail or a Dewalt.
I have a dewalt track saw and park side, so I’m thinking the makita one is more versatile with different saws. What do people think?
Did you buy the Evolution ST2800 rails?I use 1000mm Stabila level to line up two 1400mm rails. I also have the rails drilled and countersunk so I can screw the rails down - I did this because I had some heavy structural timber to rip and the accuracy was more important than the screw holes it left.
