Jenx
- Joined
- 27 Sep 2007
- Messages
- 1,978
- Reaction score
- 0
johnny.t.":398gaffp said:Jenx":398gaffp said:I've found two 13" x 11/2" Sycamore Blanks in the 'wood mound'... so they will do nicely for further attempts. They're a little bit 'bland', but.........
I got told a little trick by a turner at a craft fair Sunday, he had these little oak boxes that were jet black and he said you do it by soaking wire wool in vinegar for a bit,then rub it over the oak and hey presto. The reason I tell you this is that he said it also works on sycamore but darkens it rather than turning it black. This gave me an idea to try it on a sycamore platter, doing the rim bit dark and leaving the 'bowl' bit light. I haven't tried it yet because I haven't any wire wool and all my sycamore has these nasty brightly coloured 'stains' through the middle :lol: :roll: .
Could be an idea to make your (as yet unmade)sycamore platter less bland?
If you already know of this technique and its rubbish(like I said I've not tried) then just disregard all of the above :roll: :wink: .
JT
Cheers for that JT ... i knew about steel wool and its effects on the tannin-rich oak, but hadn't heard of this with vinegar for the sycamore..
Doesn't have to be Sarsons does it ?
be tempted to give that a go ! .. I have some small blanks in Syc', so may try a test on one of those..
--I've a wee plan to try some chestnut spirit stain to try and 'lift' the otherwise slightly bland pieces that I have, at least on one of them, anyway .. Not sure whether i'm in favour of staining in that manner or not.. I guess it'll depend on the end result ! .. I'm thinking the royal blue stain with the contrast against the pale of the sycamore 'could' work... Guess I will have to see it in the flesh, before deciding whether its nice or not
Thanks again for the tip ... has anyone else tried the vinegar / steelwool trick that John refers to ? ..
