JamiePattison
We have an Ideal boiler (combi) with 2 settings on the LCD display that controls it.
One for heating the water the other for the central heating. As per the instructions that were given to us years ago we were advised to leave the water setting to the on status so when the tank gets low on hot water it would automatically heat up until the desired temperature has reached and turn off as needed.
For the central heating it does almost the opposite, the status is set to auto and i input the time for Mon -Fri and weekends setting the time it should come on and turn off. There are 3 statuses, on, off and auto.
When the status is on or auto, if a separate dial that controls the central heating temperature is set to 0 the heating does not come on.
If it's set to a temperature then it will come on and switch off once that temperature is reached.
If this dial is set to a temperature BUT the LCD display unit has not been configured to come on i.e. the status is off or the time had not been set then the central heating doesn't come on.
Is the auto setting correct for the central heating? Or if I left it to ON ALL THE TIME would this result in higher gas charges? My assumption is the auto is set 3 times a day for 1 hour intervals and I think if the status is set to on it probably work in the same manner as the water setting where it heats up and turns off as required?
