HamsterJam
Let’s take it apart to see what’s inside….
We had Worcester 50Cdi in our previous house and that did have a pre-heat function for the hot water. (Although we never used it.)Is this possible on a WB 37cdI greenstar?
Look for the ECO button on the front display.Is this possible on a WB 37cdI greenstar?
Infrared thermometer on the hot water outlet from the boiler or in your case the hot water store / At the tap outlet ( which will be a lower temperature) due to length of the pipe run - a thermometer placed into a cup will give you the temperature at the tap . All is subject to the correct set up of your boiler/ hot water store not to mention limescale , and incorrect pipe sizes most important is the gas supply to the boiler. There is no simple approach to this post as per my comments above there are many factors that can affect the h/water temperature.How does one measure boiler temperature output - i.e. how to determine just how hot is the water leaving the boiler (on a typical condensing boiler and how to check it)?
The easiest way is to have two clip on dial thermometers so you have one on boiler output (flow) and one on the return to the boiler (return). If you are able to control the boiler output independently for both central heating and domestic hot water, then adjust your boiler output to around 65 and observe your temperature readings (leave 15 minutes to stabilise). The key parameter is the return temperature to the boiler which you should try to keep below 55C to achieve maximum condensation and thus get best efficiency.How does one measure boiler temperature output - i.e. how to determine just how hot is the water leaving the boiler (on a typical condensing boiler and how to check it)?
