Last year, I made some planters. The posts were 47mm x 47mm redwood and the rails 30mm x 47 mm redwood treated with clear wood preserver. The side panels were made from 18mm x 144mm treated exterior V-Jointed Tongue & Groove with clear wood preserver applied to the cut ends. I cut 18mm grooves in the posts, top and bottom rails and formed stub tenons to join the rails to the posts. All the woodwork (except the mortice and tenons) was primed, undercoated and with one top coat before glue up. Having glued up, I used frame sealant to seal the gaps at the bottom of the panels to avoid water ingress in to the grooves.
SWMBO was anxious to have the planters finished so I glued up with Evostick Resin W weatherproof that was probably two years old as I didn’t have any of my usual TB 111 to hand at the time. The problem is that after 8 months many of the joints have failed.
My intention is to try and knock the joints apart, clean off the old glue and re-glue with new TB 111.
Two questions:
1. I was going to scrape the glue off the tenons with a cabinet scraper and try and use a chisel to clean the mortices before using some abrasive to finish the job? Is this the best way?
2. Is the use of a frame sealant a good idea to stop water seeping into the bottom grooves or would it be better to remove the inner wall of the groove and put a nail in the centre of each piece of panelling to hold them in place?
Thanks again, in advance, for any advice
Two questions:
