PaulR":1lsdz0tj said:
not sure this is my next purchase, but a lot of what i aim to make is square faced so thinking this could get rid of one of the jobs I hate (the sanding) or at least reduce it significantly, hope Nibbo see's this and gives a review
watched a wood whisperer podcast and saw him use his, 5 seconds and he'd sanded something that would take me about 15 minutes, every time i've sanded a big flat surface since i've remembered that podcast
Olly, bench is still in plan, actually was going to ask if you could send me the sketchup of yours (will pm you)
Yes I did get a Jet 22-44PLUS.
I really didn't think anyone would be interested in a revue :shock:
Well the first thing that hit me when I saw it was it's bigger than I imagined it would be and mine came on a frame stand not the cabinet which leads me to the weight, it's at least a two man job to lift three men would be better especially to lift the motor end, I've only used it about five or six times so far, that was to flatten hardwood door threshholds and to sand pieces for an LCD TV stand to put on my boat as the stand that came with the TV was utter rubbish.
So how does it perform
As I've already warned the main part is heavy 85kg then add the extension tables and you are talking about 100kg (220lbs) add a stand with strong locking wheels and your talking 120kg in excess of 250lbs
The chap I bought mine off also included 40 80 120 240 grit loadings all full rolls not used
The 2.4HP motor is very quiet, infact I can't hear if it's running when I turn on my Sip dust/chip collector. and talking of collecting the dust there is no real noticeable dust present during operation.
So far I've only tried to load it once with 80 grit and reading the manual after doing it I found I should have started at the outer end and finished at the motor end
It worked fine though :lol:
Conclusions.... I've never ever managed to sand anything as flat as this machine can do it not even using a random orbital, I've never done it as quick either, The smallest piece I put through it was less than 6" square, so to get a finished thickness is a job it can do with small pieces that a thickness /planer can't do. :lol: As I've already said I haven't used very much yet it's early days, all I can say is I'm very impressed so far. :lol:
Edit....
I may have been lucky as the machine I bought looked brand new and hardly used and I got it for £695 so it's worth waiting and looking for second hand.
