J-G
I've needed to replace LED Drivers for two lights. A simple matter I thought. First 'issue' a small (practical and worthy) change to the connector which is now a bayonette fitting - no real problem, it's quite easy to remove the extended bit of plastic so that the old fitting can reach the connection - but I was a little concerned that the cables are not tightly clamped.
Thought - "Hmmm, I'll have to screw the clamp plate down - - - - - "
Can you imagine my surprise to see that the 'Screws' are just screw heads moulded into the cover!!!
