kkartz1":1z4eftqx said:Cut the timber as usual so you are left with a `U` shaped wood template and then cut the internals as usual. Bear in mind that you do not have a lot of wood in surface contact with the base plate so go very very easy.
powertools":lolxjmkf said:Sorry to be the odd one out but I don't think that you could bend it after cutting it out due to the different thickness in the various sections.
cowboy682":2m9idedu said:thanks Steve
l think that must be the way to go, never thought of that,
how`s the new saw? have you mastered it yet?
stevebuk":2gqf4wr0 said:i looked at your top martin and i was impressed by it thinking i would like to make one for mine, how easy is it to change blades with the bigger table?
