Phil Russell
Very interesting thread. As I see it, there are two options: start from round bar and cut discs or start from flat plate and cut through the plate. Each has its pros and cons which I am sure you can appreciate.
If using round bar then I think that trying to cut all the way through with a mini lathe is not really on... 25mm is a long way. By all means use the lathe to scribe / cut a shallow recess around the bar to act as a guide, but then use a hacksaw to make the cut. If using plate, I advise the use of a pillar drill fitted with a good quality hole cutter. Obviously you will need to be able to clamp / secure the plate to the drill; I use a drill mounted vice. I have cut 20 and 25mm diameter discs in 6mm aluminium and 4mm mild steel using this method with no real problem.
Alternatively, ask a local machine shop if they could make them for you. I have no idea of the cost though.
A thought: do the discs need to be perfectly round? Or will you be finishing the outer diameter to fit? I ask because years ago I made a knife handle and used 6mm aluminium in part of it. I roughly cut a bit of 6mm plate and then finished it to fit by hand using grinder and filing.
Just thoughts.
Cheers, Phil
Just thoughts.
Cheers, Phil
