That's a wood lathe.
sure, but he was recommending a lathe powered by a drill, is that really better than a wood lathe? I’m guessing from your comment that a drill has more torque than a wood lathe?
If it’s all you have – maybe, but I was always taught never to cut across a circular section on a table saw. If the blade catches the work will spin! You will need to find some sort of method to hold it using G cramps or similar, not just as it is, the cramp won’t hold on the circular section. IanI certainly would not use a tablesaw for this operation.
Can you not hammer them flat, drill and pien them with even a soft nail to get the thickness you desire, the contrast might be nice, but you could get thin rod for an invisible result.I had the same thought. They aren’t thick enough, but I bought some anyway and they turned out to not be completely flat either, somewhat cone shaped. Shame because washers would be the perfect solution if they could be obtained in the right sizes ☹
If these are just essentially a trim, for appearance then why not cut them from tube, much cheaper and easier to do. Just turn down the end of one of your two components to the ID of the tube and viola.yes some context would have been helpful. I’m making walking sticks for sale on Etsy, and the metal discs act as a transition between cane and handle. So I need the process to be repeatable and quick . Using hand tools is out of the question unfortunately.
I started out using brass sheet but it results in to much cleanup. Though now I think about it, a circle cutting jig would obviously improve that and as each disc ends up with a hole in the middle (for a pin/tenon that joins the handle and cane) then I could start with the hole and use that for the jig pivot.
I should have posted here weeks ago.
