How flat is flat?
If it's that bad then go to a machine shop that grind heads for cars. Explain to them that you only want them to remove the minimum to clean up the surface. They can shave the heads of your engine to within a thousandth of an inch of flat over it's length, so a plane shouldn't be any different. Same goes for the backs of chisels.
only difference is the time it takes to set up the special holding jigs for the
tools
they all have a kind of universal jig for cylinder heads, whereas they may need to make special tools for the plane and chisel.
paul :wink:
tools
paul :wink:
Yes, that gels with what I've heard.
I have a dim memory of a metal working expert saying that correctly jigging a plane so that it's not under stress, but is held firmly enough for this process, is quite tricky.
If the plane is under stress (and thus distorted), the flat surface made while the plane was held will become non-flat when the stress is removed!!
BugBear
bb you are right, you need to use a magnetic type jig, and then the problem involves how you de magnetise afterwards, to ensure that you have not made a tool collector of a different type :?
paul :wink:
