How clamp down long piece of wood to allow routing along its length?
Thank you! I didn’t know those existed. Sounds like a good approach. I will buy one and experiment. Groovy!
Without any doubt in my mind, doing this handheld is your best option when only having a router, regardless of power rating.
Afraid of not having enough power for a deep wide cut can be bypassed by having a larger bearing on preliminary passes.
Chipping out can sometimes happen but a good sharp cutter helps along with running a marking gauge down the cut line, failing this, and definitely not recommended for an unexperienced user is a controlled backfeed precut....
Andy
