Steve Maskery
The best solution I know of is a track (or saw-board equivalent, as discussed above - both work well, the tracks are more stable, but the home-made equivalent delivers results which are just as good, you just need to take a bit more care), The Tiddles' knock-down cutting table, all made from a single sheet, it is excellent, and my track setting gauge from Workshop Essentials 1. With the right blade in the saw you will get professional results time and again, all exactly right, as accurate as, if a little slower than, using an Altendorf.
Here is a picture from my build thread, it is just perfect for home use.
I have another , similar jig for use when the piece I want is narrower than the track itself.
If you made your own track, the whole kit, apart from the saw itself, would set you back less than £30, I reckon.
S
S
