farlsborough
Seeing conflicting opinions on this (yes, I know, hard to believe!) so thought I’d do a poll. Even if you do everything by feel/eye, I’m interested to know for those who use a bench grinder whether you hone at the same angle as your primary bevel (and so end up polishing some bevel heel as well as tip) or either you try to create a larger angle on your honing bevel.
And, if you are aiming for the same angle, whether this is larger than the shallowish 25° many primary bevels are ground to.
Cheers!
Cheers!
