matthewwh
That's a really sweet design, you've got the two things that most manufacturers miss i.e. the guide correctly references off the back of the blade, and the wheelbase is wider than the blade. You also have a single screw so none of the pressure disparity issues you get with two screws and a bar. Nice one!
The only thing I can't see from the photos is whether the pad that makes contact with the blade is ball jointed (like the pad on an F clamp) to cope with tapered blades. Also how do you register for squareness?
The flipping it upside down technique is very similar to the one I recommend with the Kell 3 guide and 10mm plate glass.
I haven't worked out the exact angle but the bars on the top are 11mm so it's not much, and as with your setup you can switch between one face and the other without changing anything.
