Woodmonkey":m07gnbz4 said:What about using this for the insert plate?
http://www.ebay.co.uk/itm/370782461992? ... 1438.l2649
Just need to drill some holes in it....
maybe making some insert rings from wood on the lathe?
mseries":1qmgijgs said:My homemade table sounds the same as Eric The Vikings, only I used a very old worktop offcut
You can see the 6mm MDF ring that closes the cutter hole, I have a handful of these with different sized holes. The router is screwed into a recess on the underside of the table. Very cheap to make, easy to store, a bit of a pain to change cutters though. I should have sealed the cut edge I suppose but it was only meant as prototype ! That was about 15 years ago !
karfeef":1nmtgobt said:Nice work for a prototype, I like the high fence and vacuum attachment
Sent from my GT-I9300
