Henger woes
Wow! Thank you!
They certainly appear the same... I'll whip mine off in a while and measure it. They are a bit crude in all honesty, so perhaps the measurements aren't that crucial....we shall see!
Again, beyond the call of duty!
Thank you!
Edit : Told you they were bloody silly little things! Just got the existing one off, and gave it a quick measure...I suppose it could be a tad squashed through use, but it looks circa 30mm tall, and about the same at its fattest point. Hole at the base is about 15mm diameter..
It looks to be about 31mm in every direction. But the hole in them looks to be 20mm.
Hmmm... thinks....I should've scribbled these down at the time, maybe?
Just put the thing back, but there's only 6 screws to remove to get the arm uncovered and access the bulb anyway!
Back later, methinks!
Thanks again.
Excuse the David Bailey photographic attempts!
The hole in the metal plate - through which the bellows open end is pushed - is about 18mm diameter.
The actual opening in the bellows does appear to be 15/16mm....but is 20mm wide including the rubber ring surrounding it!
Having owned my multi cut-se since 2018 with no problems and cut hundreds of 3d jigsaws out of 1" poplar , something broke! But getting a replacement part from henger uk is driving me nuts.
The part that broke was one of the screw/bolt that clamps the blade, no problem i thought trawling through there website it shows on their exploded diagram as part no 33 ,listed as a thumb screw? As i wasn't sure listing was right i have cust/support they said to be sure they would send an e-mail picture of said screw, when that came through it was wrong, I did notice that they sold blade clamps with spare screw, so I put two in my basket only to get a message saying insufficient stock? So rang cust/support who said don't know why we've over 70 in stock!
So put my order in for two clamps with spare screws and a metal plate insert cringing at the price and then 7.50 p&p
Today my order turned up two clamps, but spare screw are just normal Allan key screws, not the square headed ones, so back onto cust/support they wanted pics on a email. So have sent that off and waiting on their reply.
Can't believe all this messing about for a broken screw.
https://www.figuurzaagjes.com/product/13622429/vierkantschroef-33
I replaced both machines blowers when refurbishing them a couple of years ago, imported from Hegner UK.
They are not cheap, then add postage and import duties.
If they pack up again they will be replaced with fish tank pumps.
Their site wont even let me in from this part of the world :mad:
When Roger Buse ran HegnerUK they were brilliant to deal with. You could phone up and chat with Roger who would offer good honest advice on any subject of fretworking or indeed Hegner machines he also carried all of the spare parts.
    170.6 KB
My apologies to Wood&wool for piggybacking/railroading your original request for Hegner information.
I butted in with a (similar) grouse about Proxxon spares in the UK, and unintentionally diverted answers to your post.
Hope we (both!) manage to find suitable solutions!
