looking at this schematic are items 9, 11, and 12 those shown in your actual picture?
That’s just relating to the collets, Nothing to do with the morse taperIf the diagram in post #33 is correct then it will unscrew, it says attach collet holder by tightening nut B, are the flats visible?
Not yet! Still on the thinking about bench. Tried the solution suggested without success. I’m thinking about boring the centre and then cutting to the taper to get it out as a last resort.
As I read it nut D holds the collet, nut B being an integral part of the taper/holderThat’s just relating to the collets, Nothing to do with the morse taper
My apologies…I’ve just re-read your solution and I agree, it should just unscrew,As I read it nut D holds the collet, nut B being an integral part of the taper/holder
asked for those photos earlier!Can you put another picture on showing the complete unit, so we can see the other end..
If I've understood this saga correctly, you had to resort to a nut splitter to get the collet retaining nut D off, but have removed the nut B (which seems to have the equivalent function to a drawbar in a milling machine) OK. So you're left with an MT2 collet chuck stuck in an externally parallel spindle.I have the maintenance manual which SCM very kindly dug out for me. It certainty shows it as a plane MT2 shank held bu a nut, which we did release. I love the warning……clearly lost on the previous owner!
