I have a staircase that the boss wants to convert from painted redwood newels to oak effect. So, what’s the best approach? The staircase has a turn so it has a half landing. The newels pass through to be visible from below. The boss doesnt want to increase the post size dramatically, they are at the moment 120mm square. They are too ‘rough’ I believe to veneer, so I’m wondering about oak faced MDF cladding. But I can’t think of any easy way of ensuring ‘perfect mitre joints with say 13mm thick sheet.
I had showed her 18mm using a mitre lock block on the spindle, which would have been the perfect solution, but that was too thick. They need to be scribed into the stairs. I don’t think I can mitre lock 13mm (which is the thinnest I think I can go). I’d wondered about biscuits, but the no 10 is right on the edge of break through and would be very close to the inner edge. So, I’m a bit stuck on how to wrap the post with perfect perfume no gap joints.
Ive removed the newel tops and sanded down one side on the off chance they were oak under the paint……nope redwood the caps are oak. I need to extend the landing newels by 70mm as the new UFH has raised the floor height. The landing newels would have needed 25mm, but the handrail was closer to the tops on the landing than going up the stairs, a bit squashed, so, if I’m extending them, might as well make them look I’m proportion.
Any other ideas?
Any suggestions on how to do the joints?
Any other ideas?
